cgal-discuss - [cgal-discuss] segment intersection outside bounds
  • To:
  • Subject: [cgal-discuss] segment intersection outside bounds
  • Date: Mon, 18 Jun 2012 17:52:14 -0400
Hi,
The following program fragment seems to show that the intersection of 2
segments can be outside their bounds. I'm still learning, so the
mistake is probably mine, but I can't find it. Help?
FYI, error.C was extracted from a much larger program and dataset.
Note that I'm using Exact_predicates_inexact_constructions_kernel and
the erroneous result was computed with a chain of Segment_2,
intersection, compare_x.
I compiled it this:
/usr/bin/g++-4.7 -O3 -frounding-math error.C -lCGAL -lmpfr -lgmp -o
error
My system is this:
Linux host 3.2.0-25-generic #40-Ubuntu SMP Wed May 23 20:30:51 UTC 2012
x86_64 x86_64 x86_64 GNU/Linux
Thanks.
// Time-stamp: </wrf/c/overprop/error.C, Mon, 18 Jun 2012, 17:41:12 EDT,
http://wrfranklin.org/>
#include <iomanip>
#include <iostream>
using namespace std;
#include <CGAL/intersections.h>
#include <CGAL/Object.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
using CGAL::Object;
using CGAL::compare_x;
using CGAL::compare_y;
using CGAL::object_cast;
// Print an expression's name then its value, possible followed by a
// comma or endl. Ex: cout << PRINTC(x) << PRINTN(y);
#define PRINT(arg) #arg "=" << (arg)
#define PRINTC(arg) #arg "=" << (arg) << ", "
#define PRINTN(arg) #arg "=" << (arg) << endl
int main() {
cout << "Intersection of 2 segments is outside their bounds." << endl;
K::Point_2 v0(63.6421, 2067.410);
K::Point_2 v1(62.7046, 2071.750);
K::Point_2 w0(62.7046, 2071.750);
K::Point_2 w1(59.8669, 2066.980);
Object obj = CGAL::intersection(K::Segment_2(v0,v1), K::Segment_2(w0,w1));
if (const K::Point_2 *xsect = object_cast<K::Point_2>(&obj)) {
cout << "Intersection found. " << PRINTC(v0) << PRINTN(v1) <<
PRINTC(w0) << PRINTN(w1) << PRINTN(*xsect);
if ((compare_x(*xsect,v0)*compare_x(*xsect,v1)>0) ||
(compare_y(*xsect,v0)*compare_y(*xsect,v1)>0) ||
(compare_x(*xsect,w0)*compare_x(*xsect,w1)>0) ||
(compare_y(*xsect,w0)*compare_y(*xsect,w1)>0)) {
cout << "\nERROR: intersection is not within bounds of edges." <<
endl;
cout << PRINTN(compare_x(*xsect,v0));
cout << PRINTN(compare_x(*xsect,v1));
cout << PRINTN(compare_y(*xsect,v0));
cout << PRINTN(compare_y(*xsect,v1));
cout << PRINTC(compare_x(*xsect,w0)) << " WRONG, should be 0" << endl;
cout << PRINTN(compare_x(*xsect,w1));
cout << PRINTN(compare_y(*xsect,w0));
cout << PRINTN(compare_y(*xsect,w1));
cout << scientific << PRINTN(xsect->x()-w0.x()) << endl;
Output:
Intersection found. v0=63.6421 2067.41, v1=62.7046 2071.75
w0=62.7046 2071.75, w1=59.8669 2066.98
*xsect=62.7046 2071.75
compare_x(*xsect,v0)=-1
compare_x(*xsect,v1)=1
compare_y(*xsect,v0)=1
compare_y(*xsect,v1)=0
compare_x(*xsect,w0)=1, WRONG, should be 0
compare_x(*xsect,w1)=1
compare_y(*xsect,w0)=0
compare_y(*xsect,w1)=1
xsect->x()-w0.x()=7.105427e-15
W. Randolph Franklin, Professor
ECSE Dept., 6026 JEC,
Rensselaer Polytechnic Inst,
110 8th St,
Troy NY, 12180 USA
(most reliable address) or
or
+1 (518) 276-6077
