- To:
- Subject: [cgal-discuss] Degenerate cases in segment delaunay graph
- Date: Wed, 04 Jul 2012 19:46:53 +0200
Dear CGAL users & developers,
with the help of the segment_delaunay_graph_2 I try to compute the medial axis for a given *non*-convex polygon.
To build the segment delaunay graph (SDG) I am adding edge by edge of the initial polygon. This should give me only weakly intersecting segments.
Now, this works perfectly for most of my polygons, however sometimes the construction of the SDG crashes:
I try to insert a new segment by
v_h=sdg.insert(p1,p2, v_h);
however within the insert routine the check SDG.is_valid() fails and the procedure crashes. But for no obvious reason (looking at the polygon). Due to the high grade of templatization the code is really hard to debug/step through for me. I also tried to find the answer by reading the paper of Karavelas, but without success.
I would be extremly thankful for any information how degenerate cases (!SDG.is_valid()) arise for weakly intersecting input segments.
Or if this could be a numerical issue, as I use the Filtered_kernel<Simple_cartesian<double> >.
Thanks in advance for your help
Best,
Cornelia Auer
- [cgal-discuss] CGAL 4.0.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 07/03/2012
- Message not available
- [cgal-discuss] Re: RE: [cgal-announce] CGAL 4.0.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 07/04/2012
- [cgal-discuss] CMake error in CGAL-4.0.1. Please wait for CGAL-4.0.2, today, Laurent Rineau (CGAL/GeometryFactory), 07/04/2012
- [cgal-discuss] Degenerate cases in segment delaunay graph, Cornelia Auer, 07/04/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Sebastien Loriot (GeometryFactory), 07/05/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Cornelia Auer, 07/05/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Menelaos Karavelas, 07/06/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Cornelia Auer, 07/06/2012
