cgal-discuss - [cgal-discuss] CGAL 4.0.1 Released, Computational Geometry Algorithms Library
  • To: ,
  • Subject: [cgal-discuss] CGAL 4.0.1 Released, Computational Geometry Algorithms Library
  • Date: Tue, 03 Jul 2012 16:43:09 +0200
The CGAL Open Source Project is pleased to announce the release 4.0.1
of CGAL, the Computational Geometry Algorithms Library.
Version 4.0.1 is a bug-fix release for version 4.0. Apart various minor
fixes in the documentation, the following has been changed since CGAL-4.0:
* 2D Voronoi Diagram Adaptor (re-added)
- The package 2D Voronoi Diagram Adaptor was temporarily removed from the
CGAL distribution because of license issues. That package is now back into
CGAL.
* 2D and 3D Geometry Kernel
- Fix a bug in the Segment_3-Triangle_3 intersection function in the case
the segment is collinear with a triangle edge.
* Algebraic Kernel
- Avoid the linking error "duplicate symbols" when two compilation units
using the algebraic kernel are linked.
* 3D Boolean Operations on Nef Polygons Embedded on the Sphere
- Fix a memory leak due to the usage of an internal mechanism that has been
replaced by boost::any. This also influences the packages 2D Boolean
Operations on Nef Polygons, 3D Boolean Operations on Nef Polyhedra, Convex
Decomposition of Polyhedra, and 3D Minkowski Sum of Polyhedra.
* 2D Arrangement
- Fix several memory leaks.
* 2D Mesh Generation
- Fix a compilation error in the header <CGAL/Mesh_2/Do_not_refine_edges.h>
when g++ version 4.7 is used.
* Surface Mesh Generation and 3D Mesh Generation
- Fix an important bug in the CGAL_ImageIO library, that could lead to wrong
result when meshing from a 3D image.
- Fix the compilation of the demo in demo/Surface_mesher, when Boost version
1.48 or 1.49 is used.
* Surface Mesh Parameterization
- Fix a memory leak.
- Fix a compatibility issue with Eigen-3.1 of Eigen_solver_traits. This fix
also affects the usage of that class in the package Surface Reconstruction
from Point Sets.
For further information and for downloading the library and its
documentation, please visit the CGAL web site: http://www.cgal.org/
Laurent Rineau, PhD
