- To:
- Cc: Menelaos Karavelas <>
- Subject: Re: [cgal-discuss] Degenerate cases in segment delaunay graph
- Date: Fri, 06 Jul 2012 14:44:29 +0200
Hello Menelaos Karavelas,
thanks for getting involved. I attached a file how I build the Segment_Delaunay_Graph_2 (SDG), it also contains a vector with the points I am inserting. I hope it's easy to read and maybe to copy and paste into some running system.
Also I attached a screenshot of the polygon - it is simple. Above that I don't even demand the polygon to be without strong intersections. I use the standard Segment_Delaunay_graph_traits_2.
Maybe it is something really simple that I'm just not seeing.
Thanks anyway for your effort.
Best,
Cornelia
PS: Just in case - is there a way to catch CGAL conditions and preconditions? Maybe to build a work around. I don't see yet, how I can check the possible non- validity of the SDG before actually inserting the segments.
Am 06.07.2012 06:57, schrieb Menelaos Karavelas:
In order to determine if this is really a bug in the code or not, you need to
provide an input instance that creates the problem. It would also make sense
to send the program that you have written that creates this kind of problems.
Regarding the choice of the kernel: Filtered_kernel<Simple_cartesian<double> > is
a bad choice. You should use the filtered traits instead. CGAL::Cartesian<CGAL::Gmpq>
and CGAL::Exact_predicates_exact_constructions_kernel should work.
One final issue: how do you know that your non-convex polygon does not have
self-intersections? Could it be that your polygon is not really simple (i.e.,
its edges strongly intersect), while you consider it to be simple?
Have you tried building the segment Delaunay graph with a traits class that
supports segment intersections?
- m.
On 5 Jul 2012, at 20:56, Cornelia Auer wrote:
Thank you very much for your response!
However using the CGAL::Exact_predicates_exact_constructions_kernel the
insertion of segments breaks even earlier. I end up in:
CGAL error: assertion violation!
Expression : !(i>s)
File :
c:\Users\bzfauerc\MyAmiraVC9\product\include\arch-Win64VC9\CGAL/In Line
: 89
Explanation: Variable used before being initialized (or CGAL bug)
All I do is:
p1=Point_2(to_exact(myDoublePoint1.x), to_exact(myDoublePoint1.y) );
p2=Point_2(to_exact(myDoublePoint2.x), to_exact(myDoublePoint2.y) );
v_h=sdg.insert(p1,p2, v_h);
I haven't tried the CGAL::Simple_cartesian<CGAL::Gmpq> Kernel yet, as I have
trouble in my working enviroment to get it properly included.
However if you see something obviously wrong the way I'm proceeding above I
would be very happy if you let me know. Or could it really be a CGAL bug?
Thanks in advance for your answer!
Best,
Cornelia Auer
Am 05.07.2012 07:56, schrieb Sebastien Loriot (GeometryFactory):
On 07/04/2012 07:46 PM, Cornelia Auer wrote:
Dear CGAL users& developers,Indeed, you should try with a kernel with exact constructions
with the help of the segment_delaunay_graph_2 I try to compute the
medial axis for a given *non*-convex polygon.
To build the segment delaunay graph (SDG) I am adding edge by edge of
the initial polygon. This should give me only weakly intersecting
segments.
Now, this works perfectly for most of my polygons, however sometimes the
construction of the SDG crashes:
I try to insert a new segment by
however within the insert routine the check SDG.is_valid() fails and the
procedure crashes. But for no obvious reason (looking at the polygon).
Due to the high grade of templatization the code is really hard to
debug/step through for me. I also tried to find the answer by reading
the paper of Karavelas, but without success.
I would be extremly thankful for any information how degenerate cases
(!SDG.is_valid()) arise for weakly intersecting input segments.
Or if this could be a numerical issue, as I use the
Filtered_kernel<Simple_cartesian<double> >.
(CGAL::Simple_cartesian<CGAL::Gmpq> or
CGAL::Exact_predicates_exact_constructions_kernel).
Sebastien.
Thanks in advance for your help
Best,
Cornelia Auer
Description: PNG image
#define SegmentDelaunayGraphExactKernel_H_
#include <list>
// define the kernels
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Cartesian_converter.h>
// typedefs for the traits and the algorithm
#include <CGAL/Segment_Delaunay_graph_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_filtered_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_2.h>
class SegmentDelaunayGraphExactKernel {
public:
typedef CGAL::Simple_cartesian<double>
CK;
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Cartesian_converter<Kernel,CK> To_Inexact;
typedef CGAL::Cartesian_converter<CK, Kernel> To_Exact;
typedef Kernel::FT
FT;
typedef CGAL::Segment_Delaunay_graph_traits_2<Kernel> Gt;
typedef CGAL::Segment_Delaunay_graph_2<Gt> SDG2;
typedef Kernel::Point_2
Point_2;
typedef SDG2::Vertex_handle
Vertex_handle;
protected:
To_Inexact to_inexact;
To_Exact to_exact;
public:
// Con(De)structor methods //
SegmentDelaunayGraphExactKernel(){};
~SegmentDelaunayGraphExactKernel() {};
SDG2 sdg;
void init();
void SegmentDelaunayGraphExactKernel :: init()
std::vector<std::pair<float, float> > inputPoints;
inputPoints.push_back(std::pair<float, float> (30.5,0.334848));
inputPoints.push_back(std::pair<float, float> (30.75 , 0.0478354));
inputPoints.push_back(std::pair<float, float> (31 , -0.287013));
inputPoints.push_back(std::pair<float, float> (31 , -0.669696));
inputPoints.push_back(std::pair<float, float> (31.25 , -1.00454));
inputPoints.push_back(std::pair<float, float> (31.5 , -1.31026));
inputPoints.push_back(std::pair<float, float> (31.75 , -1.63469));
inputPoints.push_back(std::pair<float, float> (32 , -1.95911));
inputPoints.push_back(std::pair<float, float> (32.75 , -2.28293));
inputPoints.push_back(std::pair<float, float> (32.75 , -2.08077));
inputPoints.push_back(std::pair<float, float> (32.75 , -2.04021));
inputPoints.push_back(std::pair<float, float> (32.5 , -1.83745));
inputPoints.push_back(std::pair<float, float> (32.5 , -0.861038));
inputPoints.push_back(std::pair<float, float> (32.75 , -0.430519));
inputPoints.push_back(std::pair<float, float> (33 , 0));
inputPoints.push_back(std::pair<float, float> (33.25 , 0.430519));
inputPoints.push_back(std::pair<float, float> (33.5 , 0.813202));
inputPoints.push_back(std::pair<float, float> (33.75 , 1.1886));
inputPoints.push_back(std::pair<float, float> (34 , 1.55358));
inputPoints.push_back(std::pair<float, float> (34 , 2.12132));
inputPoints.push_back(std::pair<float, float> (31.75 , 2.60615));
inputPoints.push_back(std::pair<float, float> (30.5 , 1.878));
inputPoints.push_back(std::pair<float, float> (30.25 , 1.59413));
inputPoints.push_back(std::pair<float, float> (30.25 , 0.813202));
Vertex_handle v_h;
Point_2 p1,p2;
for (int i=0;i< inputPoints.size() -1; i++) {
std::cout << i << std::endl;
p1=Point_2(to_exact(inputPoints[i].first),
to_exact(inputPoints[i].second));
p2=Point_2(to_exact(inputPoints[i+1].first),
to_exact(inputPoints[i+1].second));
p1=Point_2(to_exact(inputPoints[inputPoints.size()-1].first),
to_exact(inputPoints[inputPoints.size()-1].second));
p2=Point_2(to_exact(inputPoints[0].first),
to_exact(inputPoints[0].second));
v_h=sdg.insert(p1,p2,v_h);
assert( sdg.is_valid(true, 1) );
return ;
#endif
- [cgal-discuss] CGAL 4.0.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 07/03/2012
- Message not available
- [cgal-discuss] Re: RE: [cgal-announce] CGAL 4.0.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 07/04/2012
- [cgal-discuss] CMake error in CGAL-4.0.1. Please wait for CGAL-4.0.2, today, Laurent Rineau (CGAL/GeometryFactory), 07/04/2012
- [cgal-discuss] Degenerate cases in segment delaunay graph, Cornelia Auer, 07/04/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Sebastien Loriot (GeometryFactory), 07/05/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Cornelia Auer, 07/05/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Menelaos Karavelas, 07/06/2012
- Re: [cgal-discuss] Degenerate cases in segment delaunay graph, Cornelia Auer, 07/06/2012
