cgal-discuss - Re: [cgal-discuss] i) tools for representing 3D curves, ii) controlled-resolution tetrahedral meshing with prescribed triangulated surface
  • To:
  • Subject: Re: [cgal-discuss] i) tools for representing 3D curves, ii) controlled-resolution tetrahedral meshing with prescribed triangulated surface
  • Date: Thu, 05 Jul 2012 08:11:51 +0200
On 06/29/2012 08:34 PM, Audette, Michel A. wrote:
Dear CGAL users,
I would like to enquire about a couple of research issues:
i) does CGAL support the discretization of 3D curves as a series of beam
elements?
If I understand correctly your question, an anisotropic mesher is currently under development.
ii) I know that you had begun an implementation of tetrahedral meshing that
could provide controlled-resolution results as well as remain faithful to an
input triangulated surface, but my results with this algorithm of a year were
less than convincing... I'm wondering if this algorithm has been further
validated over the past year or so?
What do you mean by "controlled-resolution"?
Sebastien
Best wishes,
Michel
Michel Audette, Ph.D.
Assistant Professor,
Department of Modeling, Simulation and Visualization Engineering,
Old Dominion University,
Norfolk, VA.
  • Re: [cgal-discuss] i) tools for representing 3D curves, ii) controlled-resolution tetrahedral meshing with prescribed triangulated surface, Sebastien Loriot (GeometryFactory), 07/05/2012
