cgal-discuss - Re: [cgal-discuss] Re: General_Polygon_with_holes_2 not valid
  • To:
  • Subject: Re: [cgal-discuss] Re: General_Polygon_with_holes_2 not valid
  • Date: Thu, 05 Jul 2012 08:32:00 +0200
On 07/05/2012 08:29 AM, cnng0315 wrote:
if one of the vertex from the hole is out of the outer bounday just a little,
is there any method to solve this? I got the point data from AutoCAD, and I
believe the data precision in AutoCAD is much lower than in CGAL. in
AutoCAD, the vertex is on one line,but construct them using CGAL's point and
line, then test and found the point is not the line.
One solution is to split the line and add this vertex as one boundary vertex.
Sebastien
technology change life!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/General-Polygon-with-holes-2-not-valid-tp4655366p4655370.html
