cgal-discuss - Re: [cgal-discuss] CGAL with Eclipse Indigo in osx 10.7
  • To:
  • Subject: Re: [cgal-discuss] CGAL with Eclipse Indigo in osx 10.7
  • Date: Fri, 06 Jul 2012 12:05:04 +0200
On 07/05/2012 01:45 PM, hugodelgado wrote:
Hi. I'm using cgal and been able to fully compile and use the examples and
demos with the cmake scripts. I've started to use the XCode and used cmake
to create the project files for eclipse for a required cgal demo, everything
works fine but the XCode is pretty annoying and i would like to use the
eclipse in my development instead of the XCode, but i couldn't get the same
demo to be compiled with eclipse. I've copied the demo directory to a new
directory and imported into a new Eclipse project, but it keeps getting
errors with unresolved symbols from QApplication and erros with no rule to
make a specific target.
To me it's not clear whether you generated a new eclipse project using cmake directly or convert a Xcode project to an eclipse one.
Could you indicate in which situation you are?
Sebastien.
I think i've all the required files since if i compile with XCode or unix
makefiles it works. Have anyone have a similar problem, or know where i can
find some hints to configure Eclipse?
Thanks
Hugo
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-with-Eclipse-Indigo-in-osx-10-7-tp4655375.html
