- To:
- Subject: [cgal-discuss] Re: Removing degenerate facets from polyhedra
- Date: Thu, 19 Jul 2012 22:05:10 -0700 (PDT)
First see the preconditioning of each join method, and make sure that you
satisfy them in each case.
Second I tried to simplify a mesh by myself using the join functions, and I
ran into a similar problem, but in my case the faces weren't degenerate, and
mostly my mistake probably was that I couldn't detect correctly when the
join leads to intersections. But when I used the simplification mechanism I
had no problems.
It would be quite helpful if you could print the triangulation (or just the
neighborhood) before you make a join failed attempt.
Third you probably need at least
Exact_predicates_inexact_constructions_kernel, and I would have tried
exact_exact just to see what happens.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Removing-degenerate-facets-from-polyhedra-tp4655484p4655496.html
- [cgal-discuss] Re: Removing degenerate facets from polyhedra, Zohar, 07/20/2012
