- To:
- Subject: [cgal-discuss] Re: Problem with make_mesh_3
- Date: Mon, 30 Jul 2012 06:07:28 -0700 (PDT)
I forgot to tell you the error generated at the compilation :
typedef CGAL::Polyhedral_mesh_domain_with_features_3< IGT, Polyhedron >
Mesh_domain;
// That line generates a bug
*typedef CGAL::Mesh_triangulation_3< Mesh_domain >::type Tr;
The bold line generates this :
error: no type named ‘Triangle_handle’ in ‘class
CGAL::Triangle_accessor_3<CGAL::Polyhedron_3<CGAL::Epick,
CGAL::Polyhedron_items_3, CGAL::HalfedgeDS_default, std::allocator<int>
>, CGAL::Mesh_3::Robust_intersection_traits_3<CGAL::Epick> >
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-make-mesh-3-tp4655492p4655624.html
- [cgal-discuss] Re: Problem with make_mesh_3, (continued)
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/20/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Sebastien Loriot (GeometryFactory), 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Mariette Yvinec, 07/26/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/30/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Laurent Rineau (CGAL/GeometryFactory), 07/30/2012
