cgal-discuss - [cgal-discuss] Re: ployhedron_3 dont run because qt plugin is not valid
  • To:
  • Subject: [cgal-discuss] Re: ployhedron_3 dont run because qt plugin is not valid
  • Date: Thu, 19 Jul 2012 22:08:45 -0700 (PDT)
Make sure the the dlls in the path are from the qt bin that you compiled the
plugins with (the could be similar dlls at other applications directories in
the path). Use the 'which' command, which you can download from cygwin for
example.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/ployhedron-3-dont-run-because-qt-plugin-is-not-valid-tp4655481p4655497.html
