- To:
- Subject: Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh
- Date: Thu, 02 Aug 2012 13:45:50 +0200
Could you indicate how you detect that there are dangling vertices?
Sebastien.
On 07/26/2012 11:25 PM, Catherine Proulx wrote:
Hi,
I'm using make_surface_mesh to build a mesh from an isosurface. The
resulting mesh looks good, but appears to have "dangling" vertices, i.e.
vertices not part of any face.
I'm using the Manifold_tag, my model is a single connected component,
and bounding box appears correctly initialized. Apart from those
dangling vertices, the mesh appears properly connected and well formed.
Is that the expected behavior of the function? And if not, any ideas on
what could be the cause of this?
Thanks,
Catherine
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Sebastien Loriot (GeometryFactory), 08/02/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Catherine Proulx, 08/07/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Catherine Proulx, 08/08/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Sebastien Loriot (GeometryFactory), 08/13/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Catherine Proulx, 08/15/2012
- Re: Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Laurent Rineau (CGAL/GeometryFactory), 08/16/2012
