cgal-discuss - Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh
  • To:
  • Subject: Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh
  • Date: Wed, 8 Aug 2012 10:24:41 -0400
I think I was able to trace back to the source of the problem.
If I use the output_surface_facets_to_off function, I can see that some facets are not considered on the surface, and thus are not output in the final model. I assume that the dangling vertices belong to those facets.
Is there a reason why this would be the case after a make_surface_mesh() operation?
Catherine
On Tue, Aug 7, 2012 at 11:55 AM, Catherine Proulx <> wrote:
Hello Sebastien,
Here is how dangling vertices are detected:
We convert the mesh to a polyhedron, using:
     CGAL::output_surface_facets_to_polyhedron
then loop through the vertices with
   for( VCI vi = polyhedron.vertices_begin(); vi != polyhedron.vertices_end(); ++vi)
then the faces with
     for( FCI fi = polyhedron.facets_begin(); fi != polyhedron.facets_end(); ++fi)
as part of the conversion to our own mesh class.
Any vertices not part of a face are considered "dangling".
On Thu, Aug 2, 2012 at 7:45 AM, Sebastien Loriot (GeometryFactory) <> wrote:
Could you indicate how you detect that there are dangling vertices?
Sebastien.
