- To:
- Subject: Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh
- Date: Wed, 15 Aug 2012 16:33:56 -0400
Hello Sébastien,
Thanks for your answer.
Yes, the patch you provided does seem to fix the problem (at least on my test cases). Any ideas on if/when this will be incorporated in an official release?
Catherine
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Sebastien Loriot (GeometryFactory), 08/02/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Catherine Proulx, 08/07/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Catherine Proulx, 08/08/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Sebastien Loriot (GeometryFactory), 08/13/2012
- Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Catherine Proulx, 08/15/2012
- Re: Re: [cgal-discuss] Dangling vertices in output of make_surface_mesh, Laurent Rineau (CGAL/GeometryFactory), 08/16/2012
