- To:
- Subject: Re: [cgal-discuss] problem with CGAL and CMAKE
- Date: Thu, 02 Aug 2012 16:52:15 +0200
Le 02/08/2012 16:35, Laurent Rineau (CGAL/GeometryFactory) a écrit :
I'm not Petr Felkel, so those are not the relevant pats for my case.
Have you used the "install" target of the solution? Maybe there is a bug with
the installation on Windows. I must admit it has never been tested as far as I
know.
I say so because it seems that you have CGAL libraries in D:/winappl/CGAL/lib/
but the CGAL sources are in D:/winappl/CGAL-3.8/. Is my guess correct?
But I tried both installing and using CGAL from its build directory, and I checked both generated CGALConfig.cmake, which behave this way if I'm not mistaken.
I reckon the problem is not the *value* of CGAL*_LIBRARY but the fact that one tries to link against it explicitly somewhere...
Anthony
- Re: [cgal-discuss] problem with CGAL and CMAKE, Laurent Rineau (CGAL/GeometryFactory), 08/02/2012
- Re: [cgal-discuss] problem with CGAL and CMAKE, Anthony Truchet, 08/02/2012
- Re: Re: [cgal-discuss] problem with CGAL and CMAKE, Laurent Rineau (CGAL/GeometryFactory), 08/02/2012
- Re: [cgal-discuss] problem with CGAL and CMAKE, Anthony Truchet, 08/03/2012
- Re: Re: [cgal-discuss] problem with CGAL and CMAKE, Laurent Rineau (CGAL/GeometryFactory), 08/03/2012
- Re: [cgal-discuss] NEW problem with CGAL and CMAKE, Anthony Truchet, 08/03/2012
