cgal-discuss - Re: Re: [cgal-discuss] problem with CGAL and CMAKE
  • To:
  • Subject: Re: Re: [cgal-discuss] problem with CGAL and CMAKE
  • Date: Thu, 02 Aug 2012 17:05:54 +0200
Le jeudi 02 août 2012 16:52:15 Anthony Truchet a écrit :
> Le 02/08/2012 16:35, Laurent Rineau (CGAL/GeometryFactory) a écrit :
> > Have you used the "install" target of the solution? Maybe there is a bug
> > with the installation on Windows. I must admit it has never been tested
> > as far as I know.
> > I say so because it seems that you have CGAL libraries in
> > D:/winappl/CGAL/lib/ but the CGAL sources are in D:/winappl/CGAL-3.8/. Is
> > my guess correct?
> I'm not Petr Felkel, so those are not the relevant pats for my case.
> But I tried both installing and using CGAL from its build directory, and
> I checked both generated CGALConfig.cmake, which behave this way if I'm
> not mistaken.
Strange. Which version of of CGAL do you use?
The CGALConfig.cmake in the build directory, and the one in the installation
directory should be different. And the bug should be only in the installed
one.
> I reckon the problem is not the *value* of CGAL*_LIBRARY but the fact
> that one tries to link against it explicitly somewhere...
That is equivalent. So far, when auto-linking is enabled, we have chosen to
have those variables empty. The dual approach would be, as you suggest, to
have always non-empty (and correct) values for those variables, but not use
them when the auto-linking is used. That sounded more complicated to
implement, and we have chosen to use empty variables.
Laurent Rineau, PhD
