cgal-discuss - [cgal-discuss] [HELP] error LNK2005 and error LNK2019
  • To: ,
  • Subject: [cgal-discuss] [HELP] error LNK2005 and error LNK2019
  • Date: Mon, 10 Sep 2012 11:12:30 +0900
---------- Forwarded message ----------
Date: Fri, Aug 31, 2012 at 2:01 AM
To:
Dear Sir/ Madam,
Good day to you.
I have installed CGAL 3.9 and boost 1.49 for my project and I believe I have
made the correct settings for my project using Microsoft Visual Studio 2010.
I tried to build a simple CGAL program as shown below:
#include <iostream>
#include <CGAL\Exact_predicates_inexact_constructions_kernel.h>
#include <CGAL\convex_hull_2.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_2 Point_2;
int main()
        Point_2 points[5] = { Point_2(0, 0), Point_2(10, 0), Point_2(10, 10),
Point_2(6, 5), Point_2(4, 1) };
        Point_2 result[5];
        Point_2 *ptr = CGAL::convex_hull_2( points, points+5, result );
        std::cout << ptr - result << " points on the convex hull" <<
std::endl;
        return 0;
When I compiled this, I got a lot of warnings but no errors as shown below:
1>------ Build started: Project: Cgal_Hello, Configuration: Debug Win32 ------
1>  hello_world.cpp
1>c:\boost_1_49_0\boost\type_traits\detail\has_binary_operator.hpp : warning
C4819: The file contains a character that cannot be represented in the current
code page (932). Save the file in Unicode format to prevent data loss
1>c:\program files (x86)\cgal-3.9\include\cgal
\extended_euclidean_algorithm.h : warning C4819: The file contains a character
that cannot be represented in the current code page (932). Save the file in
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
When I build the project, I got the following errors:
1>libboost_thread-vc100-mt-gd-1_49.lib(thread.obj) : error LNK2005: "public:
__thiscall std::basic_string<char,struct std::char_traits<char>,class
std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class
std::allocator<char> >(char const *)" (??0?$basic_string@DU?
$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@PBD@Z) already defined in
msvcprtd.lib(MSVCP90D.dll)
std::allocator<char> >::~basic_string<char,struct std::char_traits<char>,class
std::allocator<char> >(void)" (??1?$basic_string@DU?$char_traits@D@std@@V?
$allocator@D@2@@std@@QAE@XZ) already defined in msvcprtd.lib(MSVCP90D.dll)
char const * __thiscall std::basic_string<char,struct
std::char_traits<char>,class std::allocator<char> >::c_str(void)const " (?
c_str@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEPBDXZ)
static unsigned int __cdecl std::char_traits<char>::length(char const *)" (?
length@?$char_traits@D@std@@SAIPBD@Z) already defined in
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: static void __cdecl
std::char_traits<char>::assign(char &,char const &)" (?assign@?
$char_traits@D@std@@SAXAADABD@Z) already defined in libboost_thread-vc100-mt-
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: unsigned int __thiscall
std::allocator<char> >::size(void)const " (?size@?$basic_string@DU?
$char_traits@D@std@@V?$allocator@D@2@@std@@QBEIXZ) already defined in
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: __thiscall
std::_String_val<char,class std::allocator<char> >::~_String_val<char,class
std::allocator<char> >(void)" (??1?$_String_val@DV?
$allocator@D@std@@@std@@QAE@XZ) already defined in libboost_thread-vc100-mt-
std::allocator<char>::allocator<char>(void)" (??0?$allocator@D@std@@QAE@XZ)
already defined in libboost_thread-vc100-mt-gd-1_49.lib(thread.obj)
1>libboost_thread-vc100-mt-gd-1_49.lib(thread.obj) : error LNK2019: unresolved
external symbol "__declspec(dllimport) public: __thiscall
std::_Container_base12::~_Container_base12(void)" (__imp_??
1_Container_base12@std@@QAE@XZ) referenced in function __unwindfunclet$??0?
$_String_val@DV?$allocator@D@std@@@std@@QAE@V?$allocator@D@1@@Z$0
std::_Container_base12::_Container_base12(void)" (__imp_??
0_Container_base12@std@@QAE@XZ) referenced in function "public: __thiscall
std::_String_val<char,class std::allocator<char> >::_String_val<char,class
std::allocator<char> >(class std::allocator<char>)" (??0?$_String_val@DV?
$allocator@D@std@@@std@@QAE@V?$allocator@D@1@@Z)
external symbol "__declspec(dllimport) public: void __thiscall
std::_Container_base12::_Orphan_all(void)" (__imp_?
_Orphan_all@_Container_base12@std@@QAEXXZ) referenced in function "public:
__thiscall std::_String_val<char,class std::allocator<char>
>::~_String_val<char,class std::allocator<char> >(void)" (??1?$_String_val@DV?
external symbol "__declspec(dllimport) void __cdecl std::_Xlength_error(char
const *)" (__imp_?_Xlength_error@std@@YAXPBD@Z) referenced in function
"public: void __thiscall std::basic_string<char,struct
std::char_traits<char>,class std::allocator<char> >::_Xlen(void)const " (?
_Xlen@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEXXZ)
external symbol "__declspec(dllimport) void __cdecl std::_Xout_of_range(char
const *)" (__imp_?_Xout_of_range@std@@YAXPBD@Z) referenced in function
std::char_traits<char>,class std::allocator<char> >::_Xran(void)const " (?
_Xran@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEXXZ)
1>D:\Cgal_Hello\Debug\Cgal_Hello.exe : fatal error LNK1120: 5 unresolved
externals
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Anyone know the reasons behind these errors? How can I solve these problem?
Thank you very much.
Regards,
Saw
Best Regards,
Saw Seow Hui
Lecturer
Faculty of Information and Communication Technology
Department of Computer Science
University Tunku Abdul Rahman (UTAR)
Jalan Universiti, Bandar Barat,
31900 Kampar, Perak.
