cgal-discuss - [cgal-discuss] CGAL newbie question
  • To:
  • Subject: [cgal-discuss] CGAL newbie question
  • Date: Sun, 9 Sep 2012 08:18:29 +0200
Hi all,
I used the "Triangle" library from http://www.cs.cmu.edu/~quake/triangle.html by Jonathan Shewchuck to generate a Delaunay triangulation
of my raw x,y,z points. I am trying to create an indexing structure and some distance bounds that make the shortest path calculation on a
terrain faster + some other queries like range queries, and k-nearest neighbour queries as well.
I noticed that in order to do some of these things I might need CGAL, but I understand that the learning curve can be quite steep.
The things I need to do are :
1. Generate TINs at multiple levels of details by introducing Steiner points.
2. Being able to access the triangles and its adjacent triangles in raw form (like 0 1 2 vertices of triangle in counter-clockwise format)
so that I can feed it to a "Chen and Han" shortest path implementation by O'Rourke (http://cs.smith.edu/~orourke/ShortestPaths/
3. Have the ability to compute the slope of each triangle and also all its interior angles.
4. Need to be able to *project* onto the terrain the 3D euclidean line between any two points of the terrain.
5. Generate a Voronoi diagram from the Delaunay (Triangle generates this too)
Someone who used CGAL mentioned that traversing over faces of a triangulation in CGAL can be quite cumbersome and that I should
instead convert it to a polyhedron and use the iterator there. So I just want to understand if CGAL will be able to help me with all the
things I need to do and if I might get stuck halfway? Hopefully CGAL will not be overkill for what I am trying to do? I found another C++
library that used the DECL (http://www.holmes3d.net/graphics/dcel/), would this be easier to use than CGAL for what I am trying to achieve?
I ask since I am not going to do very complicated computational geometry related work on the surface, if CGAL would be too much to work with?
Thanks,
Manu
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
- Michelangelo
