- To:
- Subject: Re: [cgal-discuss] Installation issues
- Date: Thu, 11 Oct 2012 12:49:30 +0200
Le jeudi 11 octobre 2012 03:39:11 skauf a écrit :
> Hi all,
> I'd like to install CGAL in such a way that would allow me to compile
> programs that use it with MinGW on Windows.
> By default, the cmake configuration targets Visual Studio. I don't see
> instructions in the installation menu or in the lists on how to change this.
> Anyone know how to get this to work?
> Also, even when VS is the target compiler, cmake complains about not finding
> boost threads. I did set a BOOST_ROOT env var and cmake seems to be aware
> of its value, but still this happens:
> CMake Error at cmake/modules/FindBoost.cmake:917 (message):
> Unable to find the requested Boost libraries.
> Boost version: 1.51.0
> Boost include path: C:/Temp/boost_1_51_0
> The following Boost libraries could not be found:
> boost_thread
> No Boost libraries were found. You may need to set Boost_LIBRARYDIR to
> the
> directory containing Boost libraries or BOOST_ROOT to the location of
> Boost.
> I even tried to set Boost_LIBRARYDIR (say to C:/Temp/boost_1_51_0/libs) but
> that didn't help.
You can Set Boost_DEBUG to TRUE, in the CMake cache, to understand why CMake
cannot find the suitable boost_thread library.
How have you installed Boost in C:/Temp/boost_1_51_0/? What is there in
C:/Temp/boost_1_51_0/libs/?
Laurent Rineau, PhD
- [cgal-discuss] Installation issues, skauf, 10/11/2012
- Re: [cgal-discuss] Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- [cgal-discuss] Re: Installation issues, skauf, 10/11/2012
- Re: [cgal-discuss] Re: Installation issues, Philipp Moeller, 10/11/2012
- Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- Re: Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- Re: Re: [cgal-discuss] Re: Installation issues, skauf, 10/11/2012
- Re: Re: Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- Re: Re: Re: [cgal-discuss] Re: Installation issues, skauf, 10/11/2012
- Re: Re: Re: Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
