cgal-discuss - Re: Re: Re: [cgal-discuss] Re: Installation issues
  • To:
  • Subject: Re: Re: Re: [cgal-discuss] Re: Installation issues
  • Date: Thu, 11 Oct 2012 08:38:10 -0700 (PDT)
Apparently if I delete the cmake cache the cmake GUI asks which toolchain to
use, and I can select MinGW. Unfortunately, it seems like what I want to do
is not meant to be:
My MinGW is actually not the canonical version but rather the version that
ships with "Rtools" (R the statistical computing language). Cmake doesn't
have built-in configuration for this tollchain variant, and it is not
trivial to trick it into thinking this is a standard MinGW.
So unless someone has successfully built R packages that use CGAL and can
advise, I think I'll just give up.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Installation-issues-tp4656010p4656020.html
