- To:
- Subject: Re: Re: Re: Re: [cgal-discuss] Re: Installation issues
- Date: Thu, 11 Oct 2012 17:47:50 +0200
Le jeudi 11 octobre 2012 08:38:10 skauf a écrit :
> Apparently if I delete the cmake cache the cmake GUI asks which toolchain to
> use, and I can select MinGW. Unfortunately, it seems like what I want to do
> is not meant to be:
> My MinGW is actually not the canonical version but rather the version that
> ships with "Rtools" (R the statistical computing language). Cmake doesn't
> have built-in configuration for this tollchain variant, and it is not
> trivial to trick it into thinking this is a standard MinGW.
You probably just have to fix you PATH environment variable! I doubt CMake
hardcodes the path to mingw.
Laurent Rineau, PhD
- Re: [cgal-discuss] Installation issues, (continued)
- Re: [cgal-discuss] Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- [cgal-discuss] Re: Installation issues, skauf, 10/11/2012
- Re: [cgal-discuss] Re: Installation issues, Philipp Moeller, 10/11/2012
- Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- Re: Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- Re: Re: [cgal-discuss] Re: Installation issues, skauf, 10/11/2012
- Re: Re: Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- Re: Re: Re: [cgal-discuss] Re: Installation issues, skauf, 10/11/2012
- Re: Re: Re: Re: [cgal-discuss] Re: Installation issues, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
- Re: Re: Re: Re: [cgal-discuss] Re: Installation issues, skauf, 10/11/2012
