- To:
- Subject: Re: [cgal-discuss] Effect of orientation on boolops
- Date: Wed, 7 Nov 2012 14:55:58 +0200
There is no such thing as a CW oriented (valid) polygon.
A polygon-with-holes may have holes, which are CW.
On Wed, Nov 7, 2012 at 1:41 PM, Shriramana Sharma <> wrote:
Hello it's me again.
From the boolops doc I understand that counterclockwise oriented
polygons are considered to be filled and clockwise oriented ones as
"holes".
From the doc it is not clear to me whether, if I perform a union of a
CCW oriented polygon P and a CW oriented one Q, then it would
effectively act as if I had performed difference of P - Q? I mean, a
CW polygon is effectively the negative of the CCW polygon, right?
While the conditions listed in 19.2.1
(http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Boolean_set_operations_2/Chapter_main.html#Subsection_19.2.1)
say that "valid polygons" should be CCW oriented, it is not clear
whether the output of the boolops on polygons with CW orientation is
defined or not.
Could someone please shed light on this? Thanks.
Shriramana Sharma
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
- [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/07/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/07/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/07/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/08/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/08/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Sebastien Loriot (GeometryFactory), 11/08/2012
- Message not available
- RE: [cgal-discuss] Effect of orientation on boolops, Moore Rollo (THE ROYAL MARSDEN NHS FOUNDATION TRUST), 11/12/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/13/2012
