- To:
- Subject: [cgal-discuss] Re: Bug with do_intersect?
- Date: Tue, 13 Nov 2012 23:33:40 -0800 (PST)
I see, Stefan.
So let's say if I want to check whether any two or more of the polygon inside of polygon list do intersect ( in the sense that they have overlapping area, not sharing edges or sharing points), which method I should use?
I want the method to be a fast one, thus, I want the method be able to use something like inexact construction exact predicate thing. If possible.
On Wed, Nov 14, 2012 at 3:29 PM, Stefan Schirra [via cgal-discuss] <[hidden email]> wrote:
A quote from the manual:On 14.11.2012 04:11, Graviton wrote:
> I think that there is a bug with the method do_intersect.
> Test this sample:
> /*! \file do_intersect.cpp
> * Determining whether two triangles intersect.
> #include <CGAL/Exact_predicates_exact_constructions_kernel.h>
> #include <CGAL/Boolean_set_operations_2.h>
> typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
> typedef Kernel::Point_2 Point_2;
> typedef CGAL::Polygon_2<Kernel> Polygon_2;
> #include "print_utils.h"
> int main ()
> Polygon_2 P;
> //P.push_back (Point_2 (-1,1));
> //P.push_back (Point_2 (0,-1));
> //P.push_back (Point_2 (1,1));
> P.push_back (Point_2 (13371696.6813195, -23135667.773556));
> P.push_back (Point_2 (13368240.604, -23133412.8));
> P.push_back (Point_2 (13364140.624, -23133192.28));
> P.push_back (Point_2 (13368823.9405681, -23134726.6078103));
> std::cout << "P = "; print_polygon (P);
> Polygon_2 Q;
> //Q.push_back(Point_2 (-1,-1));
> //Q.push_back(Point_2 (1,-1));
> //Q.push_back(Point_2 (0,1));
> Q.push_back(Point_2 (13375139.672, -23136795.756));
> Q.push_back(Point_2 (13371696.6813195, -23135667.773556));
> Q.push_back(Point_2 (13371696.682, -23135667.774));
> Q.push_back(Point_2 (13368823.9405681, -23134726.6078103));
> Q.push_back(Point_2 (13298835.453, -23111797.193));
> Q.push_back(Point_2 (13374018.867, -23140216.837));
> std::cout << "Q = "; print_polygon (Q);
> if ((CGAL::do_intersect (P, Q)))
> std::cout << "The two polygons intersect in their interior." <<
> std::endl;
> else
> std::cout << "The two polygons do not intersect." << std::endl;
> return 0;
> If you notice carefully, the P and Q are not intersecting each other ( two
> points of P and Q are the same, and the other two points of P are located on
> the RHS of Q).
> But from the above program, the CGAL:do_intersect returns a true. It should
> return a false.
"do_intersect(obj1, obj2) checks whether obj1 and obj2 intersect. Two objects
obj1 and obj2 intersect if there is a point p that is part of both obj1 and obj2..."
So if P and Q have two common points, as you say, true is the correct answer.
best regards
Stefan
http://cgal-discuss.949826.n4.nabble.com/Bug-with-do-intersect-tp4656236p4656238.htmlIf you reply to this email, your message will be added to the discussion below:
View this message in context: Re: Bug with do_intersect?
- [cgal-discuss] Bug with do_intersect?, Graviton, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Ophir Setter, 11/14/2012
- [cgal-discuss] Re: Bug with do_intersect?, goshhukha, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Stefan Schirra, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Efi Fogel, 11/15/2012
