- To:
- Subject: [cgal-discuss] Re: Bug with do_intersect?
- Date: Tue, 13 Nov 2012 23:37:33 -0800 (PST)
Stefan, I can't agree with you on this. This is because if this were my code:
Polygon_2 P;
P.push_back (Point_2 (0,0));
P.push_back (Point_2 (1,0));
P.push_back (Point_2 (0,1));
std::cout << "P = "; print_polygon (P);
Polygon_2 Q;
Q.push_back(Point_2 (1,0));
Q.push_back(Point_2 (1,1));
Q.push_back(Point_2 (0,1));
std::cout << "Q = "; print_polygon (Q);
if ((CGAL::do_intersect (P, Q)))
std::cout << "The two polygons intersect in their interior." <<
std::endl;
else
std::cout << "The two polygons do not intersect." << std::endl;
return 0;
Then do_intersect will return a false, depite that P and Q also sharing two
of the same points.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-with-do-intersect-tp4656236p4656241.html
- [cgal-discuss] Bug with do_intersect?, Graviton, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Ophir Setter, 11/14/2012
- [cgal-discuss] Re: Bug with do_intersect?, goshhukha, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Stefan Schirra, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Efi Fogel, 11/15/2012
