- To:
- Subject: Re: [cgal-discuss] Bug with do_intersect?
- Date: Wed, 14 Nov 2012 17:00:40 +0100
On 14.11.2012 08:34, Ophir Setter wrote:
I checked the manually the also the "intentions" of the code.
The function do_intersect should return true if the two polygons "intersect in
their interior".
Ophir
OK, I see, the special case of (General_)Polygon(_with_holes)_2 and the general case of do_intersect(obj1, obj2) are handled differently, for whatever reasons.
So if you intersect triangles (like
Polygon_2 P;
P.push_back (Point_2 (0,0));
P.push_back (Point_2 (1,0));
P.push_back (Point_2 (0,1));
Polygon_2 Q;
Q.push_back(Point_2 (1,0));
Q.push_back(Point_2 (1,1));
Q.push_back(Point_2 (0,1));
) as triangles, you get different results?
On Wed, Nov 14, 2012 at 9:28 AM, Stefan Schirra
<mailto:>>
wrote:
On 14.11.2012 04:11, Graviton wrote:
I think that there is a bug with the method do_intersect.
Test this sample:
/*! \file do_intersect.cpp
* Determining whether two triangles intersect.
#include <CGAL/Exact_predicates_exact___constructions_kernel.h>
#include <CGAL/Boolean_set_operations___2.h>
typedef CGAL::Exact_predicates_exact___constructions_kernel Kernel;
typedef Kernel::Point_2 Point_2;
typedef CGAL::Polygon_2<Kernel> Polygon_2;
#include "print_utils.h"
int main ()
Polygon_2 P;
//P.push_back (Point_2 (-1,1));
//P.push_back (Point_2 (0,-1));
//P.push_back (Point_2 (1,1));
P.push_back (Point_2 (13371696.6813195, -23135667.773556));
P.push_back (Point_2 (13368240.604 <tel:%2813368240.604>,
-23133412.8));
P.push_back (Point_2 (13364140.624 <tel:%2813364140.624>,
-23133192.28 <tel:23133192.28>));
P.push_back (Point_2 (13368823.9405681, -23134726.6078103));
std::cout << "P = "; print_polygon (P);
Polygon_2 Q;
//Q.push_back(Point_2 (-1,-1));
//Q.push_back(Point_2 (1,-1));
//Q.push_back(Point_2 (0,1));
Q.push_back(Point_2 (13375139.672 <tel:%2813375139.672>,
-23136795.756));
Q.push_back(Point_2 (13371696.6813195, -23135667.773556));
Q.push_back(Point_2 (13371696.682, -23135667.774));
Q.push_back(Point_2 (13368823.9405681, -23134726.6078103));
Q.push_back(Point_2 (13298835.453, -23111797.193));
Q.push_back(Point_2 (13374018.867 <tel:%2813374018.867>,
-23140216.837));
std::cout << "Q = "; print_polygon (Q);
if ((CGAL::do_intersect (P, Q)))
std::cout << "The two polygons intersect in their interior." <<
std::endl;
else
std::cout << "The two polygons do not intersect." << std::endl;
return 0;
If you notice carefully, the P and Q are not intersecting each other
( two
points of P and Q are the same, and the other two points of P are
located on
the RHS of Q).
But from the above program, the CGAL:do_intersect returns a true. It
should
return a false.
A quote from the manual:
"do_intersect(obj1, obj2) checks whether obj1 and obj2 intersect. Two
objects obj1 and obj2 intersect if there is a point p that is part of both
obj1 and obj2..."
So if P and Q have two common points, as you say, true is the correct
answer.
best regards
Stefan
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] Bug with do_intersect?, Graviton, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Ophir Setter, 11/14/2012
- [cgal-discuss] Re: Bug with do_intersect?, goshhukha, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Stefan Schirra, 11/14/2012
- Re: [cgal-discuss] Bug with do_intersect?, Efi Fogel, 11/15/2012
