Re: [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections
- To:
- Subject: Re: [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections
- Date: Tue, 20 Nov 2012 11:41:12 +0100
The result is correct, it reports 3 intersections because 3 triangles
are intersected, and the primitive is a triangle.
They are many solutions to avoid that but it depends on what is your final goal.
Sebastien.
On 11/20/2012 02:05 AM, alef wrote:
Hello everybody,
Problem: My code computes multiple identical intersections of a segment with
a polyhedron.
I try to solve the following problem from
examples/AABB_tree/AABB_polyhedron_facet_intersection_example.cpp
The kernel is defined exactly as follow:
/typedef CGAL::Gmpq FT;
typedef CGAL::Lazy_exact_nt<FT> RT;
typedef CGAL::Simple_cartesian<RT> K;/
the tetrahedron is defined by:
/Point p1(1.0, 0.0, 0.0);
Point q1(0.0, 1.0, 0.0);
Point r1(0.0, 0.0, 1.0);
Point s1(0.0, 0.0, 0.0);
polyhedron.make_tetrahedron(p1, q1, r1, s1);/
The segment is defined by:
/Point a(0.25, 0.25, 1.0);
Point b(-0.25, -0.25, 1.0);
Segment segment_query(a,b);/
The intersection is performed by:
/std::vector<Object_and_primitive_id> intersections;
tree.all_intersections(segment_query, std::back_inserter(intersections));/
The result should be: 1 intersection at (0,0,1).
But the it gives me 3 intersections each one at (0,0,1). Is it normal or is
it a bug? if it is a bug then what could be the solution?
Cordially,
Adrien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/AABB-tree-all-intersections-Multiple-identical-intersections-tp4656289.html
- [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections, alef, 11/20/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections, Sebastien Loriot (GeometryFactory), 11/20/2012
- Re: [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections, Lefieux Adrien, 11/20/2012
- [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections, alef, 11/21/2012
- Re: [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections, Sebastien Loriot (GeometryFactory), 11/21/2012
