Re: [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections
- To:
- Subject: Re: [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections
- Date: Wed, 21 Nov 2012 22:18:04 +0100
On 11/21/2012 08:55 PM, alef wrote:
Thank you Sebastien for your answer.
Actually, I tried my code alse with segment primitives instead of triangle
primitives but it appears that every polyhedron in the tree has its own
segments so I get again multiple identical solutions. Of course, I can write
a function to check how many intersection are unique but I wondered if there
are any approaches in CGAL and where I can find them.
In the end, I would like to consider a triangulation of a domain in R^3 and
say to get its intersection with a plane. It is likely that the plane is
going to intersect with a ridge and this ridge is possibly common to many
polyhedra. Hence I would like to get only one intersection because the
common ridge can be uniquely defined.
So you have a triangulated surface and you want to intersect it with a plane. Is that right?
If yes, there is a plugin of the polyhedrondemo "Intersect Polyhedra"
which is taking two triangulated polyhedra and compute the intersection polyline.
You can emulate the plane by taking the restriction to the bbox of the surface and triangulate it.
Sebastien.
Thank you,
Adrien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-AABB-tree-all-intersections-Multiple-identical-intersections-tp4656295p4656306.html
- [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections, alef, 11/20/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections, Sebastien Loriot (GeometryFactory), 11/20/2012
- Re: [cgal-discuss] AABB_tree all_intersections: Multiple identical intersections, Lefieux Adrien, 11/20/2012
- [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections, alef, 11/21/2012
- Re: [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections, Sebastien Loriot (GeometryFactory), 11/21/2012
