cgal-discuss - [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections
  • To:
  • Subject: [cgal-discuss] Re: AABB_tree all_intersections: Multiple identical intersections
  • Date: Wed, 21 Nov 2012 11:55:41 -0800 (PST)
Thank you Sebastien for your answer.
Actually, I tried my code alse with segment primitives instead of triangle
primitives but it appears that every polyhedron in the tree has its own
segments so I get again multiple identical solutions. Of course, I can write
a function to check how many intersection are unique but I wondered if there
are any approaches in CGAL and where I can find them.
In the end, I would like to consider a triangulation of a domain in R^3 and
say to get its intersection with a plane. It is likely that the plane is
going to intersect with a ridge and this ridge is possibly common to many
polyhedra. Hence I would like to get only one intersection because the
common ridge can be uniquely defined.
Thank you,
Adrien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-AABB-tree-all-intersections-Multiple-identical-intersections-tp4656295p4656306.html
