cgal-discuss - Re: [cgal-discuss] mesh example?
  • To: "" <>
  • Subject: Re: [cgal-discuss] mesh example?
  • Date: Wed, 12 Dec 2012 23:53:10 -0500
There are good examples in CGAL/examples/Mesh_3 for both cases that you are after.
I am not familiar with 3Dircad dataset, but I noticed that you are running you are code from "Mesh_2" directory, is that just a coincident?
On Wed, Dec 12, 2012 at 9:59 AM, Randy Heiland <> wrote:
Hello,  Can someone point me to an example use of generating a 3D tetrahedral mesh from either input points/polyhedra or a stack of images?
I blindly tried this (after downloading the 3Dircad* dataset), which seemed to run several seconds, but apparently produced no output:
~/dev/CGAL/CGAL_build/demo/Mesh_2$ mesh 3Dircadb2.1/MESHES_VTK.zip
# Shewchuk Triangle .poly file, produced by the CGAL::Mesh_2 package
# Neither attributes nor boundary markers are used.
0 2 0 0
0 0
Mesh points: 0
Mesh triangles: 0
