- To:
- Subject: Re: [cgal-discuss] mesh example?
- Date: Thu, 13 Dec 2012 11:05:34 -0500
Thanks! I had only looked in /demo, where /Mesh_3 was essentially empty. But now I see I can build several pgms in /examples/Mesh_3 and just need to figure out how they work :)
On Wed, Dec 12, 2012 at 11:53 PM, Hamid G <> wrote:
There are good examples in CGAL/examples/Mesh_3 for both cases that you are after.I am not familiar with 3Dircad dataset, but I noticed that you are running you are code from "Mesh_2" directory, is that just a coincident?On Wed, Dec 12, 2012 at 9:59 AM, Randy Heiland <> wrote:
Hello, Can someone point me to an example use of generating a 3D tetrahedral mesh from either input points/polyhedra or a stack of images?
I blindly tried this (after downloading the 3Dircad* dataset), which seemed to run several seconds, but apparently produced no output:
~/dev/CGAL/CGAL_build/demo/Mesh_2$ mesh 3Dircadb2.1/MESHES_VTK.zip
# Shewchuk Triangle .poly file, produced by the CGAL::Mesh_2 package
# Neither attributes nor boundary markers are used.
0 2 0 0
0 0
Mesh points: 0
Mesh triangles: 0
- [cgal-discuss] mesh example?, Randy Heiland, 12/12/2012
- Re: [cgal-discuss] mesh example?, Hamid G, 12/13/2012
- Re: [cgal-discuss] mesh example?, Randy Heiland, 12/13/2012
- Re: [cgal-discuss] mesh example?, Andreas Fabri, 12/13/2012
