- To:
- Subject: Re: [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception
- Date: Wed, 23 Jan 2013 12:06:22 +0100
Le mercredi 23 janvier 2013 02:44:33 thann a écrit :
> Hi Laurent,
> I'd rather experience boring but simple-to-fix issues than this one :)
> Here is the extended make log.
> <http://cgal-discuss.949826.n4.nabble.com/file/n4656548/make_v.txt>
> Note that that the gcc used to build is placed in /Users/tobias/usr/bin/ and
> Qt's qmake is used on top of make.
In your CMake log, there was the line "Building shared libraries", that means
that the value of the CMake variable BUILD_SHARED_LIBS was "TRUE". But in you
complete build log one can see that the linker links with the *static*
library
/Users/tobias/Dev/CGAL/CGAL-4.1_build/lib/libCGAL.a
That is the only strange thing I found out in your logs.
Laurent Rineau, PhD
- [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, (continued)
- [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, thann, 01/23/2013
- Re: [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
