- To:
- Subject: Re: [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception
- Date: Wed, 23 Jan 2013 10:58:01 +0100
My guess is that you do not have exception handling on.
Could you try adding the option -fexceptions or something similar (look at the compiler manual)?
Thanks,
Sebastien.
On 01/23/2013 10:39 AM, thann wrote:
Yes, I added a --version to the cxx flags:
g++ -c -pipe --version -std=c++11 -frounding-math -g -gdwarf-2 -arch
x86_64 -mmacosx-version-min=10.5 -Wall -W -DQT_GUI_LIB -DQT_CORE_LIB
-DQT_SHARED -I/usr/local/Qt4.8/mkspecs/macx-g++ -I.
-I/Library/Frameworks/QtCore.framework/Versions/4/Headers
-I/usr/include/QtCore
-I/Library/Frameworks/QtGui.framework/Versions/4/Headers
-I/usr/include/QtGui -I/usr/include -I. -F/Library/Frameworks -o
cgalmain.o src/cgalmain.cc
g++ (GCC) 4.7.2
Copyright (C) 2012 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Uncaught-CGAL-Uncertain-conversion-exception-tp4656528p4656539.html
- [cgal-discuss] Uncaught CGAL::Uncertain_conversion_exception, thann, 01/22/2013
- Re: [cgal-discuss] Uncaught CGAL::Uncertain_conversion_exception, Sebastien Loriot (GeometryFactory), 01/23/2013
- [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, thann, 01/23/2013
- Re: [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- [cgal-discuss] Re: Uncaught CGAL::Uncertain_conversion_exception, thann, 01/24/2013
