cgal-discuss - Re: [cgal-discuss] Re: Normals of the facets of a Skin Surface
  • To:
  • Subject: Re: [cgal-discuss] Re: Normals of the facets of a Skin Surface
  • Date: Sun, 3 Feb 2013 14:33:26 +0100
For rendering you normally need the normal in every vertex, not on a face. Since all faces are triangles, you can just take the normal to the triangle. The orientation of all triangles is consistent so that you'll get all normals pointing either inside or outside.
Bests,
Nico
On Sun, Feb 3, 2013 at 12:30 AM, J-B <> wrote:
Thank you a lot for your help.
So I succeded in accessing normals (I am printing out the skin surface in Pymol and the result is far better but not perfect yet) but the normals seem to be linked with a point only (vertex) and not with a facet.
To have the normal of the facet, I have to to the average of the normals of the points of the halfedge or there is a more direct way ?
Anyway, it resolved my issue (I take one point of the facet and its normals is considered roughly as the normal of the facet).
If you are interested here is my project Github.
Good night.
2013/2/2 Nico Kruithof-3 [via cgal-discuss] <[hidden email]>
See the skin_surface_subdiv_with_normals.cpp example. This does what you want.
Nico
On Sat, Feb 2, 2013 at 11:05 PM, J-B <[hidden email]> wrote:
Hello,
I am building a skin surface and trying to display it. To do so, I need to
have the normals of the facets (normals that go outside of the "object").
I do not even know if the skin surface does know the inside and the outside
of the shape.
Is it possible to obtain this ?
Thank you for your help.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Normals-of-the-facets-of-a-Skin-Surface-tp4656641.html
Nico Kruithof
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Normals-of-the-facets-of-a-Skin-Surface-tp4656641p4656642.html
To unsubscribe from Normals of the facets of a Skin Surface, click here.
NAML
View this message in context: Re: Normals of the facets of a Skin Surface
Nico Kruithof
nghk.nl
