- To:
- Subject: Re: [cgal-discuss] installing LibQGLviewer on windows
- Date: Mon, 04 Feb 2013 14:46:43 +0100
On 02/04/2013 11:52 AM, sara ershadi wrote:
I am using this and CGAL manual too . I have worked a lot to install allI guess, you built all qt with examples and demo.
the required Lib for CGAL . since I have 64 bit version windows I
compilde QT from source it takes on My cori5 laptop 12 hourse too
install Qt open source every where truly .
Only two targets were needed:
nmake sub-src
nmake sub-tools
I have problem with LibQGLviewer But I install it truly I am using thisWhat did not work in the instructions here?
link for LibQGLviewer :
http://www.libqglviewer.com/
http://www.libqglviewer.com/examples/index.html
http://www.libqglviewer.com/compilation.html
http://www.cgal.org/windows_installation.html#libQGLViewer
Sebastien.
thanks
sara
*To:*
*Sent:* Monday, February 4, 2013 2:15 PM
*Subject:* Re: [cgal-discuss] installing LibQGLviewer on windows
This guide should help:
Sebastien.
On 02/04/2013 11:42 AM, sara wrote:
> Hi all,
> I tried a lot to run CGAL demo on Linux . But It can not work still.
> I have installed All required Lib in windows and CGAL too . I did all
stages
> truly .
> But about LibQGLviewer there is an error in CMake when I want to build
> AABB_demo in windows.
> I have compiled teh Lib
> QGLviewer truly with visuall studio and Qt and replace the resulted
.llb in
> windows/system folder
> Please help me since this is very important for me to run CGAL demo.
> Thanks in advance.
> sara
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/installing-LibQGLviewer-on-windows-tp4656645.html
> Sent from the cgal-discuss mailing list archive at Nabble.com
<http://nabble.com/>.
- [cgal-discuss] installing LibQGLviewer on windows, sara, 02/04/2013
- Re: [cgal-discuss] installing LibQGLviewer on windows, Sebastien Loriot (GeometryFactory), 02/04/2013
- Re: [cgal-discuss] installing LibQGLviewer on windows, sara ershadi, 02/04/2013
- Re: [cgal-discuss] installing LibQGLviewer on windows, sara ershadi, 02/05/2013
