cgal-discuss - Re: [cgal-discuss] installing LibQGLviewer on windows
  • To: "" <>
  • Subject: Re: [cgal-discuss] installing LibQGLviewer on windows
  • Date: Tue, 5 Feb 2013 01:14:01 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=11epWTvCu8VO6Hllh++RPPjMvlyAwOebNi8gMQqEmkIL2d2whFmP7VlxMyBRyOKUwwzWU1brbwJnlZJ6b3ANQuAR9mKL1b/3TTDOo6GoD2QbUM7XOb3wHCWWS8rbmPzM7agfDUYup/QYbpY0aTe9pDBXcIo8XF0ElTCyOEI9v7E=;
I have 64 bit windows . and Qt opensource every where installed in it.
I have visuall studio 2010 .
1- to open visuall studio command prompt what kind of it I should open . visual studio command prompt or visual studio win64 command prompt ?
2- I want to run Qt demo . I go to demo folder and double click on .pro file . for example
C:\dev\qt-everywhere-opensource-src-4.8.3\qt-everywhere-opensource-src-4.8.3\demos\affine
but when it opens with Qt creator then I press debug and run it ends with the folowing error :
Failed to start program. Path or permissions wrong?
C:\dev\qt-everywhere-opensource-src-4.8.3\qt-everywhere-opensource-src-4.8.3\demos\affine\debug\affine.exe exited with code -1
Starting C:\dev\qt-everywhere-opensource-src-4.8.3\qt-everywhere-opensource-src-4.8.3\demos\affine\debug\affine.exe...
I tried alot and once one of Qt demo run truly and others have this error .
Thanks a lot for your help and comment . I should present about CGAL demo in upcomming days .I hope I be able to run it's demo till the session
Thanks
Sara
To:
Sent: Monday, February 4, 2013 5:46 AM
On 02/04/2013 11:52 AM, sara ershadi wrote:
> I am using this and CGAL manual too . I have worked a lot to install all
> the required Lib for CGAL . since I have 64 bit version windows I
> compilde QT from source it takes on My cori5 laptop 12 hourse too
> install Qt open source every where truly .
I guess, you built all qt with examples and demo.
Only two targets were needed:
    nmake sub-src
    nmake sub-tools
> I have problem with LibQGLviewer But I install it truly I am using this
> link for LibQGLviewer :
> http://www.libqglviewer.com/
> http://www.libqglviewer.com/examples/index.html
> http://www.libqglviewer.com/compilation.html
What did not work in the instructions here?
http://www.cgal.org/windows_installation.html#libQGLViewer
Sebastien.
> thanks
> sara
> *From:* Sebastien Loriot (GeometryFactory) <>
> *To:*
> *Sent:* Monday, February 4, 2013 2:15 PM
> *Subject:* Re: [cgal-discuss] installing LibQGLviewer on windows
> This guide should help:
> Sebastien.
> On 02/04/2013 11:42 AM, sara wrote:
>  > Hi all,
>  > I tried a lot to run CGAL demo on Linux . But It can not work still.
>  > I have installed All required Lib in windows and CGAL too . I did all
> stages
>  > truly .
>  > But about LibQGLviewer there is an error in CMake when I want to build
>  > AABB_demo in windows.
>  > I have compiled teh Lib
>  > QGLviewer truly with visuall studio and Qt and replace the resulted
> .llb in
>  > windows/system folder
>  > Please help me since this is very important for me to run CGAL demo.
>  > Thanks in advance.
>  > sara
>  > View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/installing-LibQGLviewer-on-windows-tp4656645.html
>  > Sent from the cgal-discuss mailing list archive at Nabble.com
> <http://nabble.com/>.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
