- To:
- Subject: Re: [cgal-discuss] Applying a functor to CGAL iterator ranges.
- Date: Tue, 05 Feb 2013 11:49:37 -0800
On 2/5/2013 8:19 AM, Ross Hemsley
wrote:
I am
writing a class with a series of functions that work by
applying
functors
to an iterator range over a set of elements.
Example:
template<
typename Iterator, typename Functor >
double
mean(Iterator begin, Iterator end, Functor f)
double sum = 0;
int count = 0 ;
for (Iterator i=begin; i!=end; ++i)
sum += f(*i);
++count;
However,
I now want to use the
"Triangulation_2::finite_vertices_iterator"
as the
iterator, and I want to apply a functor that requires access
to the
vertex_handle.
- This is a problem because the algorithm above dereferences
the
iterator and gives me a plain vertex: The problem is that
dereferencing
the
iterator that CGAL gives us causes us to lose information.
I'm
looking for a solution that keeps the same input parameters
(an iterator
with
'::value_type' that corresponds to the argument of the
functor).
But
may work differently 'under the hood' - i.e. we have a
special
helper
function "apply(f, x)" that applies a function to an
iterator.
I tried to use some dirty 'template magick' tricks to do
this but
the
ideas I had require features that are only reliably
available in C++11.
Any
ideas?
Depending on what you're iterating over it sounds like you could kludge this by creating a sequence filled with pointers to your actual iterators. It's certainly not elegant, though. Cody |
- [cgal-discuss] Applying a functor to CGAL iterator ranges., Ross Hemsley, 02/05/2013
- Re: [cgal-discuss] Applying a functor to CGAL iterator ranges., Cody Rose, 02/05/2013
- [cgal-discuss] Re: Applying a functor to CGAL iterator ranges., RossH, 02/05/2013
- Re: [cgal-discuss] Re: Applying a functor to CGAL iterator ranges., Cody Rose, 02/05/2013
- [cgal-discuss] Re: Applying a functor to CGAL iterator ranges., RossH, 02/06/2013
- Re: [cgal-discuss] Applying a functor to CGAL iterator ranges., Philipp Moeller, 02/05/2013
