cgal-discuss - [cgal-discuss] Re: Sequence of boolops on general polygons
  • To:
  • Subject: [cgal-discuss] Re: Sequence of boolops on general polygons
  • Date: Wed, 6 Feb 2013 00:36:47 +0530
On Tue, Feb 5, 2013 at 4:36 PM, Shriramana Sharma
wrote:
> Should I simply use this line with the above Traits_2 and I will get a
> type I can use for multiple successive operations as described above?
I have since come across bezier_traits_adapter2.cpp within the
examples dir (but not mentioned in the documentation) which clearly
uses
typedef CGAL::Gps_traits_2<Traits_2> Bezier_traits;
typedef CGAL::General_polygon_set_2<Bezier_traits> Bezier_polygon_set;
so I guess that's what I'll use too. BTW I have a small patch for this
example which I attach. Would be nice if it could be incorporated for
a future release.
Shriramana Sharma
Attachment: bezier_traits_adapter2.patch
Description: Binary data
