cgal-discuss - Re: [cgal-discuss] Re: Sequence of boolops on general polygons
  • To:
  • Subject: Re: [cgal-discuss] Re: Sequence of boolops on general polygons
  • Date: Tue, 5 Feb 2013 21:56:33 +0200
You should be fine with following that example in order to compute bops of beizer curve.
On Tue, Feb 5, 2013 at 9:06 PM, Shriramana Sharma <> wrote:
On Tue, Feb 5, 2013 at 4:36 PM, Shriramana Sharma <> wrote:
> Should I simply use this line with the above Traits_2 and I will get a
> type I can use for multiple successive operations as described above?
I have since come across bezier_traits_adapter2.cpp within the
examples dir (but not mentioned in the documentation) which clearly
uses
typedef CGAL::Gps_traits_2<Traits_2>                    Bezier_traits;
typedef CGAL::General_polygon_set_2<Bezier_traits>      Bezier_polygon_set;
so I guess that's what I'll use too. BTW I have a small patch for this
example which I attach. Would be nice if it could be incorporated for
a future release.
Shriramana Sharma
