- To:
- Subject: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3
- Date: Mon, 18 Feb 2013 09:18:28 -0800 (PST)
Philipp Moeller-2 wrote
> The type of the function argument and the type of the argument you are
> calling it with a are not matching up. It is really hard to see where
> you go wrong or if something in the polyhedron code messes up without a
> minimal, compilable example that reproduces the problem. Can you try to
> provide one?
Yes, no problem!
The error shows up as soon as the halfedgeMesh.computeNormalCycle() function
is called, so I made a minimal building of a mesh, before calling this
function.
Here is the example: Test.zip
<http://cgal-discuss.949826.n4.nabble.com/file/n4656765/Test.zip>
Thank you!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compilation-errors-while-extending-Polyhedron-3-tp4656746p4656765.html
- [cgal-discuss] Compilation errors while extending Polyhedron_3, NMoreau, 02/17/2013
- Re: [cgal-discuss] Compilation errors while extending Polyhedron_3, Philipp Moeller, 02/17/2013
- [cgal-discuss] Re: Compilation errors while extending Polyhedron_3, NMoreau, 02/18/2013
- Re: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3, Philipp Moeller, 02/18/2013
- Re: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3, Laurent Rineau (CGAL/GeometryFactory), 02/18/2013
