- To:
- Subject: Re: [cgal-discuss] Thiessen polygons
- Date: Thu, 07 Mar 2013 09:35:11 +0100
On 03/06/2013 08:10 PM, alissonzkv wrote:
Hi friends,Yes you can. What do you need? A list of polygons or a HDS like structure (i.e. with relationship with the edges of the polygons)?
I am implementing an application that needs the Thiessen polygons. The
inputs are: the points (in coordinates) and a polygon delimiting the region,
i.e., all Thiessen polygons generated (Voronoi diagram) should be in input
polygon. Can I do this using the CGAL?
Sebastien.
Best regards,
Alisson Barbosa
Systems Analyst - FUNCEME
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Thiessen-polygons-tp4656841.html
- [cgal-discuss] Thiessen polygons, alissonzkv, 03/06/2013
- Re: [cgal-discuss] Thiessen polygons, Sebastien Loriot (GeometryFactory), 03/07/2013
- [cgal-discuss] Re: Thiessen polygons, alissonzkv, 03/07/2013
- Re: [cgal-discuss] Re: Thiessen polygons, Sebastien Loriot (GeometryFactory), 03/07/2013
