- To:
- Subject: Re: [cgal-discuss] Compiling with mingw
- Date: Fri, 8 Mar 2013 22:35:04 +0800
I read this https://svn.boost.org/trac/boost/ticket/4614
Though it is marked as fixed, but the last reply shows the problem still exists.
2013/3/8 杨成林 <>
My version is 1.532013/3/8 Laurent Rineau (CGAL/GeometryFactory) <>Le vendredi 08 mars 2013 13:37:23 æ ¨æˆ æž— a écrit :
> Boost.thread needs special treatment when using mingw. SeeIs not it a bug of Boost.Thread itself?
> http://stackoverflow.com/questions/9254791/cmake-and-boost
> CGAL_TweakFindBoost.cmake should be improved.
With which version of Boost have you tried? I would not like to hack
CGAL_TweakFindBoost.cmake to workaround a bug that may have already been
fixed.
Laurent Rineau, PhD
杨成林
Yang Chenglin
杨成林
Yang Chenglin
- [cgal-discuss] Compiling with mingw, 杨成林, 03/08/2013
- Re: [cgal-discuss] Compiling with mingw, Laurent Rineau (CGAL/GeometryFactory), 03/08/2013
- Re: [cgal-discuss] Compiling with mingw, 杨成林, 03/08/2013
- Re: Re: [cgal-discuss] Compiling with mingw, Laurent Rineau (CGAL/GeometryFactory), 03/08/2013
- Re: Re: [cgal-discuss] Compiling with mingw, 杨成林, 03/09/2013
- Re: Re: [cgal-discuss] Compiling with mingw, 杨成林, 03/14/2013
