- To:
- Subject: Re: Re: [cgal-discuss] Compiling with mingw
- Date: Thu, 14 Mar 2013 16:25:21 +0800
None else encounter this problem?
2013/3/9 杨成林 <>
I just followed the installation manual of bosst and cgal. I tried to use static libs. If BOOST_THREAD_USE_LIB is not defined, then the program will try to use dynamic lib. I think it is easy to reproduce.Le vendredi 08 mars 2013 22:35:04 æ ¨æˆ æž— a écrit :
> I read this https://svn.boost.org/trac/boost/ticket/4614How have you detected the bug? Can you please describe a procedure to help
> Though it is marked as fixed, but the last reply shows the problem still
> exists.
reproduce it?
Laurent Rineau, PhD
杨成林
Yang Chenglin
杨成林
Yang Chenglin
- [cgal-discuss] Compiling with mingw, 杨成林, 03/08/2013
- Re: [cgal-discuss] Compiling with mingw, Laurent Rineau (CGAL/GeometryFactory), 03/08/2013
- Re: [cgal-discuss] Compiling with mingw, 杨成林, 03/08/2013
- Re: Re: [cgal-discuss] Compiling with mingw, Laurent Rineau (CGAL/GeometryFactory), 03/08/2013
- Re: Re: [cgal-discuss] Compiling with mingw, 杨成林, 03/09/2013
- Re: Re: [cgal-discuss] Compiling with mingw, 杨成林, 03/14/2013
