cgal-discuss - Re: Re: [cgal-discuss] Compiling with mingw
  • To:
  • Subject: Re: Re: [cgal-discuss] Compiling with mingw
  • Date: Sat, 9 Mar 2013 21:16:54 +0800
I just followed the installation manual of bosst and cgal. I tried to use static libs. If BOOST_THREAD_USE_LIB is not defined, then the program will try to use dynamic lib. I think it is easy to reproduce.
2013/3/8 Laurent Rineau (CGAL/GeometryFactory) <>
Le vendredi 08 mars 2013 22:35:04 æ ¨æˆ æž— a écrit :
> I read this https://svn.boost.org/trac/boost/ticket/4614
> Though it is marked as fixed, but the last reply shows the problem still
> exists.
How have you detected the bug? Can you please describe a procedure to help
reproduce it?
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
杨成林
Yang Chenglin
