[cgal-discuss] CGAL doesn't like left-sided half circles ? Is it a bug or do I have a bug ?
- To:
- Subject: [cgal-discuss] CGAL doesn't like left-sided half circles ? Is it a bug or do I have a bug ?
- Date: Fri, 8 Mar 2013 12:53:53 -0800 (PST)
Hi all,
Here is a problem that is puzzling me for a while, even though it looks
basic.
*Context:* I build a 2D arrangement containing only one polyline curve.
*Problem:* There is a vertex duplication for some input curves.
Here is a code snippet ready for compilation, that gives the choice between
creating a polyline representing a left-sided circle and creating a polyline
representing a right-sided circle by tweaking the boolean value
"correct_behavior".
The polyline is then added to an arrangement. It is cut into two x-monotone
subcurves in each case. However, in the left-sided case, the cutting vertex
is duplicated and the final arrangement has 4 vertices instead of 3. If
CGAL_precondition(cgal_arr.is_valid()) is called, then the process
terminates because it finds out the vertex duplication.
This code snippet is a modification from "ex_polylines.cpp", a source code
example for "CGAL Arrangements and Their Applications".
----------------- code snippet -----------------
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arr_polyline_traits_2.h>
#include <CGAL/Arrangement_2.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Arr_segment_traits_2<Kernel> Segment_traits;
typedef CGAL::Arr_polyline_traits_2<Segment_traits> Traits;
typedef Traits::Point_2 Point_2;
typedef Traits::Curve_2 Polyline_2;
typedef CGAL::Arrangement_2<Traits> Arrangement_2;
#include <list>
#include <stdio.h>
int main(int argc, char *argv[]) {
Arrangement_2 cgal_arr;
std::list<Point_2> pts;
const bool correct_behavior = false;
if (correct_behavior) { // Builds a right-sided half circle
pts.push_back(Point_2(250, 150 ));
pts.push_back(Point_2(300, 163.397 ));
pts.push_back(Point_2(336.603, 200 ));
pts.push_back(Point_2(350, 250 ));
pts.push_back(Point_2(336.603, 300 ));
pts.push_back(Point_2(300, 336.603 ));
pts.push_back(Point_2(250, 350 ));
} else { // Builds a left-sided half circle
pts.push_back(Point_2(200, 163.397 ));
pts.push_back(Point_2(163.397, 200 ));
pts.push_back(Point_2(150, 250 ));
pts.push_back(Point_2(163.397, 300 ));
pts.push_back(Point_2(200, 336.603 ));
Polyline_2 polyline(pts.begin(), pts.end());
insert(cgal_arr, polyline);
// CGAL_precondition(cgal_arr.is_valid()); // quits if correct_behavior ==
false
// Next line prints "3 vertices" (correct cutting) if correct_behavior ==
true
// or prints "4 vertices" (incorrect) if correct_behavior == false
printf("number of vertices in the arrangement : %li\n",
cgal_arr.number_of_vertices());
----------------- end of code snippet -----------------
Please try it out, I have no hint left about where it can come from... Am I
missing something important ?
Thanks in advance.
Best Regards,
Hugo Loi
PhD student at Inria - Maverick Team
http://maverick.inria.fr/
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-doesn-t-like-left-sided-half-circles-Is-it-a-bug-or-do-I-have-a-bug-tp4656863.html
- [cgal-discuss] CGAL doesn't like left-sided half circles ? Is it a bug or do I have a bug ?, Tapadi, 03/08/2013
- Re: [cgal-discuss] CGAL doesn't like left-sided half circles ? Is it a bug or do I have a bug ?, Sebastien Loriot (GeometryFactory), 03/09/2013
