- To:
- Subject: Re: [cgal-discuss] Re: Vertex circulator starting at fixed vertex
- Date: Fri, 08 Mar 2013 22:25:32 +0100
Thanks a lot for your reply.
El 08/03/2013 16:05, Tapadi escribió:
Handles and Circulators point both at samely-typed objects (vertices for
examples), so you may be able to compare them writing (*vc==*ne) instead of
(vc==ne).
That would indeed make sense... nevertheless that expression does not even compile (!). The
alternative ( vc->handle() == ne ) does, but still produces nonsense...
Best,
Daniel
- [cgal-discuss] Vertex circulator starting at fixed vertex, DANIEL DUQUE CAMPAYO, 03/08/2013
- [cgal-discuss] Re: Vertex circulator starting at fixed vertex, Tapadi, 03/08/2013
- Re: [cgal-discuss] Re: Vertex circulator starting at fixed vertex, Daniel Duque, 03/08/2013
- Re: [cgal-discuss] Re: Vertex circulator starting at fixed vertex, Daniel Duque, 03/09/2013
- Re: [cgal-discuss] Vertex circulator starting at fixed vertex, Olivier Devillers, 03/20/2013
