- To:
- Subject: Re: [cgal-discuss] Splitting Nefs
- Date: Mon, 11 Mar 2013 19:22:01 +0100
Looks like something is weird indeed. I suspect the nef to be invalid
(even if the is_valid says the converse). Do you have the two
nefs used to produced it, together with the operation type?
Sebastien.
On 03/11/2013 06:32 PM, Noel Warren wrote:
Hi Sebastien
I actually use CGAL wrapped in ruby. You can checkout my repo at
(https://github.com/noelwarr/rgal). Let me know if you want any
licenses put anywhere. (I do know about the cgal-bindings project but I
couldn't get my head around swig.)
Because it is a pain to compile the whole RGAL repo I have put together
a little cpp file and nef file that fails to create a nef from one of
the volumes. The interesting thing is that even though the same volume
fails, it throws a different error. The cpp file complains about a
segmentation fault whereas my ruby wrapped code produces...
CGAL ERROR: assertion violation! (RuntimeError)
Expr: cet->get_index() == ce->twin()->get_index()
File: /usr/local/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1169
Even wierder is the fact that if I don't regularize the nef, the cpp
code produces a result but my ruby code continues to fail.
Let me know if you need something else.
2013/3/11 Sebastien Loriot (GeometryFactory)
<mailto:>>
Dear Noel,
could you please provide a complete compilable example showing the
problem?
Thanks,
Sebastien.
On 03/07/2013 01:13 PM, Noel Warren wrote:
I have a function that splits Nefs into smaller nefs from the
shells of
the volumes. I am doing it using an undocumented Nef
constructor. In
the majority of cases it works a charm but ocasionally it fails.
I have
attatched a nef that fails (infact it only has one volume so should
return an Array of length 1 containing a Nef) when trying to split.
Here is a code snippet
vector<Nef_polyhedron_3> nefs;
Nef_polyhedron_3::Volume___const_iterator vi = ++N.volumes_begin();
Nef_polyhedron_3::Shell_entry___const_iterator si;
CGAL_forall_volumes(vi,N) {
if(vi->mark()) {
CGAL_forall_shells_of(si, vi) {
Nef_polyhedron_3::SFace_const___handle sfch(si);
Nef_polyhedron_3 O(N,sfch);
nefs.push_back(O);
Here is the error...
Expr: itl != it->second.end()
File: /usr/local/include/CGAL/Nef_3/__SNC_external_structure.h
Line: 1102
If I shouldn't be using this Nef constructor, how should I go about
"splitting" a nef into smaller ones. Thanks in advance for your
time.
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] Splitting Nefs, Noel Warren, 03/07/2013
- Re: [cgal-discuss] Splitting Nefs, Sebastien Loriot (GeometryFactory), 03/11/2013
- Re: [cgal-discuss] Splitting Nefs, Noel Warren, 03/11/2013
- Re: [cgal-discuss] Splitting Nefs, Noel Warren, 03/12/2013
