cgal-discuss - Re: [cgal-discuss] Splitting Nefs
  • To:
  • Subject: Re: [cgal-discuss] Splitting Nefs
  • Date: Mon, 11 Mar 2013 07:13:47 +0100
Dear Noel,
could you please provide a complete compilable example showing the problem?
Thanks,
Sebastien.
On 03/07/2013 01:13 PM, Noel Warren wrote:
I have a function that splits Nefs into smaller nefs from the shells of
the volumes. I am doing it using an undocumented Nef constructor. In
the majority of cases it works a charm but ocasionally it fails. I have
attatched a nef that fails (infact it only has one volume so should
return an Array of length 1 containing a Nef) when trying to split.
Here is a code snippet
vector<Nef_polyhedron_3> nefs;
Nef_polyhedron_3::Volume_const_iterator vi = ++N.volumes_begin();
Nef_polyhedron_3::Shell_entry_const_iterator si;
CGAL_forall_volumes(vi,N) {
if(vi->mark()) {
CGAL_forall_shells_of(si, vi) {
Nef_polyhedron_3::SFace_const_handle sfch(si);
Nef_polyhedron_3 O(N,sfch);
nefs.push_back(O);
Here is the error...
CGAL ERROR: assertion violation! (RuntimeError)
Expr: itl != it->second.end()
File: /usr/local/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1102
If I shouldn't be using this Nef constructor, how should I go about
"splitting" a nef into smaller ones. Thanks in advance for your time.
