- To:
- Subject: Re: [cgal-discuss] Splitting Nefs
- Date: Tue, 12 Mar 2013 13:29:29 +0100
It seems you were right.
changing...
O = CGAL::OFF_to_nef_3(ss, N);
...to...
O = CGAL::OFF_to_nef_3(ss, N).regularisation();
...right at the beginning of my code seemed to fix the errors that end up cropping up much later.
I still have a couple of nefs that throw errors but I guess they are somehow also not valid. A bit more investigation is needed. Thanks for all your help.
2013/3/12 Noel Warren <>
The nef I sent you Is not the result of one boolean operation but dozens of them and many are generated "on the fly". The workflow looks something like...1) Build Nef using CGAL::OFF_to_Nef2) Build Nef cube manually using polyhedron incremental builder and then convert to nef. This represents our stock material.2) Build a cylinder manually using polyhedron incremental builder and then convert to nef. This represents a router bit.3) Create lots of polylines and convert to Nef. These are our toolpaths.4) Perform a minkowski sum of the previous two.5) Subtract from the stockI'm not sure where to go from here. If you managed to compile RGAL I could then I could send you some ruby scripts that produce the same errors. But RGAL is a pain to install (You need ruby 1.9.3, gems, rice...) unless you are somehow motivated to try it out because you want to.Let me know.2013/3/11 Sebastien Loriot (GeometryFactory) <>
Looks like something is weird indeed. I suspect the nef to be invalid
(even if the is_valid says the converse). Do you have the two
nefs used to produced it, together with the operation type?
Sebastien.
On 03/11/2013 06:32 PM, Noel Warren wrote:
Hi Sebastien<mailto:>>
I actually use CGAL wrapped in ruby. You can checkout my repo at
(https://github.com/noelwarr/rgal). Let me know if you want any
licenses put anywhere. (I do know about the cgal-bindings project but I
couldn't get my head around swig.)
Because it is a pain to compile the whole RGAL repo I have put together
a little cpp file and nef file that fails to create a nef from one of
the volumes. The interesting thing is that even though the same volume
fails, it throws a different error. The cpp file complains about a
segmentation fault whereas my ruby wrapped code produces...
CGAL ERROR: assertion violation! (RuntimeError)
Expr: cet->get_index() == ce->twin()->get_index()
File: /usr/local/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1169
Even wierder is the fact that if I don't regularize the nef, the cpp
code produces a result but my ruby code continues to fail.
Let me know if you need something else.
2013/3/11 Sebastien Loriot (GeometryFactory) <Nef_polyhedron_3::Volume___const_iterator vi = ++N.volumes_begin();
Dear Noel,
could you please provide a complete compilable example showing the
problem?
Thanks,
Sebastien.
On 03/07/2013 01:13 PM, Noel Warren wrote:
I have a function that splits Nefs into smaller nefs from the
shells of
the volumes. I am doing it using an undocumented Nef
constructor. In
the majority of cases it works a charm but ocasionally it fails.
I have
attatched a nef that fails (infact it only has one volume so should
return an Array of length 1 containing a Nef) when trying to split.
Here is a code snippet
vector<Nef_polyhedron_3> nefs;
Nef_polyhedron_3::Shell_entry___const_iterator si;
CGAL_forall_volumes(vi,N) {
if(vi->mark()) {
CGAL_forall_shells_of(si, vi) {
Nef_polyhedron_3::SFace_const___handle sfch(si);File: /usr/local/include/CGAL/Nef_3/__SNC_external_structure.h
Nef_polyhedron_3 O(N,sfch);
nefs.push_back(O);
Here is the error...
Expr: itl != it->second.end()https://sympa.inria.fr/sympa/__info/cgal-discuss
Line: 1102
If I shouldn't be using this Nef constructor, how should I go about
"splitting" a nef into smaller ones. Thanks in advance for your
time.
<https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] Splitting Nefs, Noel Warren, 03/07/2013
- Re: [cgal-discuss] Splitting Nefs, Sebastien Loriot (GeometryFactory), 03/11/2013
- Re: [cgal-discuss] Splitting Nefs, Noel Warren, 03/11/2013
- Re: [cgal-discuss] Splitting Nefs, Noel Warren, 03/12/2013
