cgal-discuss - Re: [cgal-discuss] suggestion about triangulation
  • To:
  • Subject: Re: [cgal-discuss] suggestion about triangulation
  • Date: Fri, 15 Mar 2013 07:00:34 +0100
You indeed can try 1, if you point cloud describe a close surface.
Another option that really depends on the point cloud sampling is using the alpha-shape [1].
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html
On 03/14/2013 04:03 PM, mario wrote:
Hi,
i'm new to CGAL and by now i only compiled them and tried to build a first
example.
My target is using CGAL in order to load an unordered 3d cloud point and to
generate a 3d object, with 3d object i mean a 3d description with vertices,
triangles and normals.
I guess there are more strategies to achieve that. I think i could try
1) "normal estimation of point" (
http://doc.cgal.org/4.2/CGAL.CGAL.Point-Set-Processing/html/index.html#Chapter_Point_Set_Processing
) plus "Surface Reconstruction from Point Sets"
(http://doc.cgal.org/4.2/CGAL.CGAL.Surface-Reconstruction-from-Point-Sets/html/index.html#Chapter_Surface_Reconstruction_from_Point_Sets)
2)"3D Triangulations"
(http://doc.cgal.org/4.2/CGAL.CGAL.3D-Triangulations/html/index.html#Chapter_3D_Triangulations)
3) other strategy that i don't know
I know i've to read and try by myself but could you suggest me the better
way to start and about what kind of input format (of unordered set of x,y,z
point) i'll have to deal with?
Best Regards, Mario
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/suggestion-about-triangulation-tp4656957.html
