- To:
- Subject: Re: [cgal-discuss] Re: suggestion about triangulation
- Date: Fri, 15 Mar 2013 12:43:42 +0100
Strange, I just tried and it worked for me (the loading, the reconstruction looked bad as there are not enough points).
Can you try with a file in the demo folder?
For example CGAL/demo/demo/Surface_reconstruction_points_3/data/ChineseDragon-points.off
Sebastien
On 03/15/2013 10:43 AM, mario wrote:
Ok,
however i downloaded Point_set_demo.exe from
http://www.cgal.org/demo/4.2/surface_reconstruction_points_3.zip
as i thought it should do strategy 1 but when i open a very simple file
like(a cube) :
OFF
8 0 0
-0.500000 -0.500000 0.500000
-0.500000 0.500000 0.500000
-0.500000 0.500000 -0.500000
-0.500000 -0.500000 -0.500000
demo crashes with message "Program received SIGSEGV: Segmentation Fault"
where i'm wrong?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/suggestion-about-triangulation-tp4656957p4656970.html
- [cgal-discuss] suggestion about triangulation, mario, 03/14/2013
- Re: [cgal-discuss] suggestion about triangulation, Sebastien Loriot (GeometryFactory), 03/15/2013
- [cgal-discuss] Re: suggestion about triangulation, mario, 03/15/2013
- Re: [cgal-discuss] Re: suggestion about triangulation, Sebastien Loriot (GeometryFactory), 03/15/2013
