- To:
- Subject: Re: [cgal-discuss] Delaunay 2D triangulation
- Date: Tue, 19 Mar 2013 18:28:38 +0100
Le 3/18/13 9:02 PM, MudaBuda a écrit :
Hello!no
Can you please tell me did you use Knuth's randomized incremental algorithm
for Delaunay triangulation?
Did you implemented the algorithm from this book that uses randomizedno
incremental algorithm?
"Computational Geometry Algorithms and Applications"
I ask this because I don't see where you implemented the first step of thethis is implementation details about how to handle the convex hull boundary.
algorithm if you worked from this book. The first step is to find a large
triangle that will contain all the set points.
Thank you very much!
We prefer to use a dummy point at infinity (see the manual)
CGAL implements the Delaunay hierarchy (for dynamic updates and fast point location)
and spatial sorting (brio) for static construction of Delaunay triangulation.
Olivier
- [cgal-discuss] Delaunay 2D triangulation, MudaBuda, 03/18/2013
- Re: [cgal-discuss] Delaunay 2D triangulation, Olivier Devillers, 03/19/2013
